Well as some of you may know I bought Pastor's protege back in January to replace my pro (totaled by a hit and run). I've had good luck with it. I recently put down 195hp at 14psi, but I'm starting to get tired of the short coming of the BP-26. So I'm going with the MS. I just started doing the research, so look out everyone that has done it before I'm sure I'll be fillin' up your PM box. I was thinking MS I with the v3.0PCB and running MSnSe for full fuel and spark. As well as DiyAutoTune.com's boost controller mod. I have an automatic throttle body, a GM IAT sensor, and I'm going to use the factory temp. sensor and dizzy. I also have a MSD 6AL with a 2-step that I'm going to try my damnedest to make work. I know lex was having problems with his, but everyone I've talked to said that there's worked just fine... so I guess we'll see. I would also like to add a knock sensor, is there a mod kit or some way of doing that?
Is there anything else I forgot?
I'm also going to finally be putting on my GTR intake manifold, porting and polishing the head and mani, a bigger FRONT mount intercooler, and putting power steering back in.
I hope to take a ton of pix along the way so stay tuned.
