No one wants to rebuild a vj-20?
    Rx8
    1988 BF GTX
    1990 x2 BG AWD Protege
    1991 Escort GT- SOLD
    2005 Corolla
      Okay I understand, RX8. However, do they plug and play in my setup? BP fuel rail, gtx head, BP fuel injector wiring harness and oval connectors?
      Also, how do I know which rx8 injectors to order on rockauto? There are a ton of different colors and styles when you look up a 2004 rx8 fuel injector.
        These are the ones I installed and they are plug an play.
          1988 BF GTX
          2005 Corolla
            All the injector info you need for the BP:
            FS Forged H beam rods
            awaiting test fit
            Aluminum CAS/Distributor caps
            BP oil jet eliminators
            EV14 fuel rail spacers
            More stuff coming soon.......
              http://www.fiveomotorsport.com/denso...rs-195500-4450
              I found these due to the supply being limited on the 4450 denso injectors. What do you all think about these? Will the body of the injector interfere with the fuel rail or harness? It appears to be applicable.
                http://www.bellengineering.net/produ...roducts_id=585
                I was able to find these, a little pricey compared to $200 but available.
                  The bell engineering denso injectors are RX8 injectors.
                  The five-o injectors are bosch ev14 universal injectors. They have been modified to fit denso applications. The EV14 are supposed to be the cats meow along with the injectors that Injector Dynamics sells.
                  Just be carefull that five-o has not modified a smaller ev14 injector to flow more. This was something they do with their "custom" denso injectors
                  awaiting test fit
                    It appears that the Five0 flow rates are identical at different fuel pressures so is it same to assume they are going to work fine?
                    DENSO Flow Rates:
                    450 cc/min at 3 bar
                    505 cc/min at 3.5 bar
                    555 cc/min at 4 bar
                    Resistance: 13.5 Ohms
                    Voltage: 8-15 Volts, Nominal 13.5 Volts
                    Amperage: 1.0 Amps
                    Pressure: Min. 36 PSI (2.5 bar), Max. 101 PSI (7 bar)
                    ______________________________________________
                    Five0 026M460X12 (195500-4450)FLOW RATES:
                    Static Flow Rate: EACH SET IS ACCOMPANIED BY A COMPLETE FLOW-SPEC SHEET
                    460 cc/min at 3.0 bar
                    555 cc/min at 4.0 bar
                    Amperage: 1.0 Amps
                      By modifying you mean taking a smaller injector and making it flow more by altering it in a way that is undesirable or such that it does something it wasn't intended to do?
                      If it were you, would you go with the densos or the five0?
