1995 EGT, MS2 PNP by Lex, BP-T with vj20/ishi hybrid, 440cc rx8 injectors, vaf delete, innovate MTX-L wideband.
Okay so as the title states the cars idles okay, is choppy an missing at times, but idles okay for all intents and purposes and does so between 13-15:1 once warmed up cylinder missing goes away.
Once the throttle is cracked, and I mean even the slightest opening of the throttle plate, the afr's go to 22.4:1 and engine dies.
Any thoughts? Does this sounds like the ecu isn't seeing the TPS? I will double check where my TPS wire is at the harness later but I'm pretty sure it is in 2L.
