I you're not too much in a hurry I could have it laser cut for you.
Price will vary with material (steel or stainless) and thickness. But I'm pretty sure it can be done for less than 60$ (unless you go 1" thick stainless).
also how thick should the wall thickness be on my pipes for the manny be?
maz1.8 i might be intouch with you.
thanks
1/2" thick would do the job nicely.
As far as pipes go, depends on what material you're using but personnally I would'nt go under .100" with steel pipes, a little thinner if stainless is used.
