Im going to get a FMIC for my car. Ive been looking under the hood and thinking of all the ways I could run the pipes, but i havent set my mind on a certain way. Anyone with a front mount that has picks of the way you ran pipes, please post the pics here. Id love to see some of the ways that were succesful.
Calling all BG's w/ front mounts
Im going to get a FMIC for my car. Ive been looking under the hood and thinking of all the ways I could run the pipes, but i havent set my mind on a certain way. Anyone with a front mount that has picks of the way you ran pipes, please post the pics here. Id love to see some of the ways that were succesful. I am running a stock vj-20 setup.sigpic
confusing... how so it comes off the turbo around the rad support to fmic out fmic around rad support & up to tb.
very simple & easy as **** to remove 2 pipes rule---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
the strange hose coming off is the recirculation valve.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by 92dxWhats the deal w/ the air filter? It looks backwards..
Wrong part number when I ordered it...but yes the cone is backward compare to the "normal" oneMazda Protege LX Touring 1999
Mazda Protege 1993 Turbo
-Megasquirt, denso 720cc injector, Forged internal, Holset HX30 Turbo, tial 38mm wg with dumptube, 3" turbo back, etc...
negative thats a sock toyota supra valve able to hold mid 20's for PSI range... its far better then the stock gtx one.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
