Everyone's setup
    Everyone's setup
    Hey guys, I'm relatively new to the protege scene, been posting around here a little bit but mostly lurking trying to absorb information. I think it would be helpful if everyone whose built a turbo engine would list their set up for example:
    -block
    -pistons
    -rods
    -head
    -cams
    -intake
    -exhaust
    -turbo
    -boost level
    -and finally performance numbers(1/4 or 1/8 or dyno)
    any other relevant details would be helpful too
    I think this has been done before, but i cant find where it was done. Heres mine,
    stock BP-05 motor
    VJ-20 turbo
    GTX ECU w/ walbro fuel pump
    FMIC
    boosting @ 8psi
    150 whp
    140 lbs/tq @ wheels
    BP-05 Turbo-Sold
    2004 MK4 AWP Jetta GLI
      This will help:
        stock BP-05 motor
        VJ-20 turbo
        FMIC
        boosting @ 8psi
        150 whp
        140 lbs/tq @ wheels
        that's all you have? what about intake manifold and stuff? that's the kind of cheap set-up i'm looking for
          yeah whats the deal elscotto I was hitting 207 @ the wheels with just a few changes from your setup.
          BP55 ECU, turbo exhintake cam, VF10 @ 8.5PSI
            I'm not there yet, but I'm just starting to gather parts and plan my build.
            -BP-05 block
            -Pistons and rods undecided so far. I'm thinking of boring it out.
            -BP-05 head
            -BP-26 cams, maybe the turbo exintake cam
            -GTR intake manifold
            -Corksport downpipe, 2.5" mandrel bent exhuast
            -VF-10/VJ-20 hyrbid
            -I don't know how much boost..........15+ PSI maybe?
            -RX-7 460cc injectors
            -Walbro 255 fuel pump
            -Megasquirt management
              nice... wish i could rebuild my engine... no one on here from B.C. to help me
                Heres what I got.
                Stock Gtx block
                BP-05 Head
                Gtx cams
                Gtx intake manifold
                Customized turbo manifold
                T3/T4 Turbo @ 15 PSI
                Turbosmart boost controller
                HKS SSQV BOV
                Haltech E6X
                MSD 6AL and Blaster SS coil
                STOCK GTX INJECTORS at only 85% duty cycle!
                Aeromotive Rising Rate Fuel Pressure Regulator
                Walbro 255lph fuel pump
                Bully Stage 3 six puck clutch..
                I think thats everything..
                Car is making SICK power with this setup.. But next year Im going for more once I change the injectors and.. *cough* do up some other suprises...
                93 MX-3
                BP, Wiseco Pistons, Pauter Rods, Haltech E6X, Turbonetics T3/T4 Ball Bearing, 3 inch turbo back exhaust, Bully Six puck clutch
                "Jesus, its raining out! I cant get traction in this!!!"
                  Read my signature and look at my cardoimain picts
                  1990 Protege 4wd: BP05 forged internals, Mild ported head, GTR intake manifold, Gates racing timing belt, GTX transmission, Stage 3 clutch, 60trim T-3 turbo, Custom down pipe,3" Stainles exhaust, , Walbro fuel pump, RB-Performance fmic kit, HKS bov, Aurfa coilovers, F&R drilled slotted rotors, 16" BBS wrapped with Advan Novea tires, EDM glass headlights with HID's, Familia front and rear bumpers.
                  Boosted 1990 4WD
                  http://www.wihandyman.com/forum/showthread.php?t=32462
                    Well you do have the vf-10 and maybe at a higher psi? I am at stock boost with the stock EGT exaust. I agree that my power is somwhat lower, but mind you my setup is very conservative.
                    The intake manifold was left stock from the BP=05 motor and does quite well, especially when I have to go and get my emissions passed. What other stuff are you talking about? For a more detailed look at what I have check out my post on how to turbo your BP-05 motor.
                    BP-05 Turbo-Sold
                      what my setup is going to consist of
                      bp05 block with miata 9:5 pistons(already have the pistons)
                      bp05 head ported with gtx cams or mike323's regrinds
                      bp58 ecu(already have)
                      gtx injectors(they're on their way)
                      vj20 or vj11
                      fmic
                      ryans cut manifold or gtr piece(not sur on this yet)
                      rx7 mafs
                      adj cam gear
                      gtx water pump
                      im going for a reliable daily driver.
                        B6t rods...
                        JE 9:1 pistons..
                        GTX head...
                        GTX intake mani...
                        GTX turbo mani with T3/T4 slapped on it....
                        EMS...
                        20 Psi..
                        301whp....
                        1/4 mile.....my best...13.9 @ 109 (traction FTL!)
                          I want a turbo. hehehehehe
                            B6t rods...
                            JE 9:1 pistons..
                            20 Psi..
                            How long have you ran this set up? Are the b6t rods really that strong??? I mean I would have thought 9:1 with 20psi wouldn't last too long on anything but H beams.
                              stock like a mo'fo!!
                              always glad to help
                              Originally posted by 90prtege
                              have you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!
                              Originally posted by Turpro
                              Fk the family. Drugs and hookers take priority first
                              bpt323: broom break
                              CRZbrussian: that sux
                              CRZbrussian: get swifer wet
                              CRZbrussian: ****s aluminum
