Ok guys this weekend i went to the track , the only diference between the last time i went there, is that i installed the GTX cams instead of the n/a ones. Made from 15.6 to 15.1 yes .5 here is the video from an in board cam i installed, sorry for the slow launch, traction issues, and also con second gear thanks to my old valeo brand pressure plate, it went almost to fuel cut, and i had to release the gas pedal and hit it back, so if i could change the pressure plate for next moth i could be in 14´s. aaahhhh and also boosting 6psi on 4 gear, i have a hole on the intercooler, and sealed it with epoxy.
You were so right about the GTX Cams vs N/A
