I have a question for those of you that have turbo'd your BG regardless of motor . That question is this, how many miles(roughly) have you put on your turbo motor/car between rebuilds, also what parts did you replace when you were forced/chose to rebuild the motor or parts of it? This question is for my personal gain as most of you know I'm under way with my turbo project for my B6D and I need to know what you guys have experienced as far as wear as I want this car to be capable of being driven relatively hard on a nearly daily basis. Yes, I know what that means, but I assure you I am building this motor for maximum reliability with boost just for fun, but I will say that my goal still remains a minimum of 250 hp. I know it sounds ridiculous to say 250 out of the B6D, but factor in the reasonably large order I'm placing with Gude Performance late Nov early Dec. and the numbers these parts are capable of handling, I won't have anything to worry about as long as I build a badass bottom end of which some parts also provided by Gude performance.
Thanks for the info.
MrH.
MrH.
