Ok so im starting to get my parts list going, and want to get the tial Q 50mm bov. Well to figure out the spring you need to know engine vac. Well how am I supposed to know that without running the motor on the setup I will have, 8.8:1 and hopefully a gtr intake manifold if I can find one. Just trying to see what you guys are running vac wise. Or am I going about this the wrong way.
here are the springs compared to vac to show what I would need to get
6psi = vac between 8 and 11
8psi = vac between 12 and 15
10psi = vac between 16 and 19
11psi = vac between 20 and 21
12psi = vac between 22 and 23
