bpt hesitation over 11psi ?
    most of u know my setup,bp05,gtx ecu,rx7 vaf, vj20, n/a intake mani ,gtx injectors ,walbouro 255,msd coil ,brk 7 plugs , fmic,turbonetics manual boost cont,4 wire tps swap not to confident in tho , and finally safc 1 tuned at 0,
    so why after 11 psi when i floor it mostly , would it hesitate also the more boost i turn up after 11 the worse it gets at 10 psi and below theres no hesitation ? i was thinkin of dropin the gtx intake mani back on an seein if that helps even ?
    what has been changed, first need to know....
    92 protege lx-
    94 protege lx-
    95 escort gt-ms2e/ms2extra pre3.3alpha5 gslender v2.8-e85-vj23@12lbs----dead--
    are you a thinker, or a believer?
      nothing oh um vaf is 6 clicks off stock rx-7 specs
        you did that and now it hesitates? do you have a wideband? when you adjusted the afm did you change any of the settings on the safc
        92 protege lx-
        94 protege lx-
          what are your plugs gaped at?
          and why do you have a safc with gtx injectors and ecu really no point
              nowide band
                Originally posted by stylingtwagon View Post
                nowide band
                Get 1. I found my problem with one
                  ok chris thats cool im done runnin 8-10 psi now tell me are the gtx injectors still souposed to handle 10-14psi ive heard the engine gets lean after 12 is that true ? has any one udes a non gtr restior box with gtr injectors ? how hard is the wiring and what do i need ?
                    or this one sorry i dont wanna get a piece of crap i know u understand ?>
                      lc1
                      92 protege lx-
                      94 protege lx-
                        the inovative ? #2
                          ya i saw it is that a pretty good one ?
