... is that due to too much fuel?
Backfire out the wastegate?
Member of MX-3.com
"Do it ONCE, do it RIGHT!"Tags: None
what are you A/F ratios when it's happening?Create your own VB Gallery here.
Well this only happened when I upped the boost on the wastegate. A lot of pow pow bang bang, sounded like an old Batman show. I'm thinking too much fuel that the MS needs to be more sensitive, change some lag times.
My A/F's were good... 11.8's while on boost. My timing should be good cause I don't get bangs when I down the boost. The spool is much quicker, as in it gets to full boost faster now so I'm thinking sensitivity on the MS.
Member of MX-3.com
If I remember correctly you have the standard 2.5Bar map sensor in there. So we might have set a boost cut at around 20-21psi since that's where the sensor maxes out at and that's exactly what it would sound like.
EDIT: We can take the boost cut off, but I don't recommend going too much above the 21psi point and there is a risk of a runaway (oh noes) turbo/boost condition that won't be stopped without the cut. It would be called overboost protection in Megatune.
Something like this:
I can look at it on MondayLast edited by Lex; 09-02-2009, 09:42 AM.
It's funny tho, it wasn't anywhere near 20psi when the backfiring started... maybe 10psi or more.
Member of MX-3.com
Yup... almost every time I stepped on the pedal. I'll try again tonight when I get home.
I love the feeling of this setting cause the boost hits a lot harder, or as in the wastegate keeps shut longer.
Member of MX-3.com
I'm thinking I have to gap my spark plugs smaller... it's probably having a misfire at high boost. It pops around 10-15psi... and only happens when I give it the beans.
I also had some popping tonight at my normal setting... gonna pull the plugs tomorrow and have a look.
Member of MX-3.com
