Can someone help me out here? I am ready to put my car back to NA before it ever hits the road.
After installing a vj20 on my 1.8l egt I was experincing lots of smoke through the tail pipe and then noticed oil leaking from under side of turbo as well as around the downpipe exhaust connection. I realized something was wrong with the turbo (or so I thought) so even though I was sooooo close I removed it and sent it off for a rebuild.
Fast forward a week or so. Vj20 back and looking really pretty with fresh rebuild. No shaft play, new paint, the works. Rebuilder had found some cranky bearings and bad seals.
So I put the thing back on a few days ago and have the same problem. This time it can't be the Turbo right? I figure it is getting too much oil. So my buddy and I get some smaller fittings for oil line, and a smaller oil feed line.
Yesterday I was back at it. Everything looks good. Until I start.
Now I have smoke, leak at turbo seal location, oil at downpipe connection AND a leak where the new fitting goes into the block. I am going to pull the rebuilt turbo off and test with another turbo we have sitting here. It does not have the fresh rebuild or the hot side jet hot coating I had done.
If the car does the same thing, what could be the problem? Anyone? Do I need to change my stock oil pump for something different? Any help appreciated. If I can't figure it out I may have a bunch of parts for sale.
