I was trying to look for the maximum wheel offset for my protege5 and if the front and rear have a different offset, if anyone can help ill sure appreciate it. Im trying to figure if a staggerd rim will fit this car...
Wheel Offset?
Offset for P5 OEM wheels is +50 mm, front and rear. Obviously the same offset since the wheels are interchangeable front to back.
and for the BG is +48 right?One day you are born,
The next big milestone
you discover go zoom-zoom
you can't get enough!
Remember, when someone annoys you, it takes 42 muscles in your face to frown, BUT, it only takes 4 muscles to extend your arm and bitch-slap that mother@#?!&! upside the head!!!
This car refuses to die! By TheMAN
I believe the BG has OEM +45 mm offset wheels.
Originally posted by cablemirc+48 is what? 48 units of what measurement, and from where?One day you are born,
does the larger the number persay 40 MM move the wheel closer to the fender or closer to the hub. VS a 30MM
thats what i always get mixed up on---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
The greater the + offset, the closer to the strut the wheel is positioned. As + offset is reduced, the wheel is moved closer to the fender (the outside). Thus, a +40 mm wheel is closer to the strut than a +30 mm wheel.
In other words, + offset refers to the distance (in mm) the centerline of the wheel is displaced inward from its mounting face. Likewise, - offset refers to how far the centerline of the wheel is displaced outward from its mounting face.
Happy Motoring!Last edited by goldstar; 03-03-2006, 06:34 AM.02 DX Millenium Red - The Penultimate Driving Machine
30MM offest W/ MX3 subframe here i come---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
