what is your transmission issue? What engine did you swap in to the 323?
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
I'd say 1st gen bg engine/tranni section would be the section you want to post in.
Hi all, engine is now 1.8L 16v SOHC motor from junkyard 1993 Protoge. Runs very well, produces a lot of power. Original engine was 1.6l - water damage head gasket blown.
Transmission issue as follows: Put in drive, goes into 2nd gear. Low gear engages 1st gear. Have to manually go from 1 to 2. 2-3 does NOT work. Can drive car, but no higher than about 60 (as if you were constantly passing people). Speedometer does not function. Is this related?
yes speedo not working is related... the ecu for the transmission needs to see a speedo reading in order to time when it shifts.. with out that its fail safed in 2nd gear only..
