hello from canada winnipeg exactly,seasons grettings....i have owned a mazda protege since 1991,a lx model also have a 1993 canadian gt dohc, great car but the rust got her, so gonna try a motor swap , the dohc standard from the 93 to the 91 sohc automatic, is it a easy swap? or does some know someone in wpg that does that kinda work?
a newbie!
Welcome to CP. Season's Greetings to you, also.
Hi Sloppy... may the 93 GT rest in pieces...let's see now...I know of about 8 of them, I have two, so 490 93 GT's to go and mine will be the only one!! lol
Yep like the others say, search that auto to manual swap... it's been covered more times than you could imagine...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
hey sloppy yeah its easy all u have to do is swap the engine and tranny out u have to keep tranny mount maybe timing belt side mount too i m not sure never done sohc to dohc but done atx to mtx so u still have to swap the pedals out and jump a wire in one of the plug i ll try to find pics now for wiring harness and ecu u have to swap that too im sure theres more to it good luck
pics below is what u have to jump wireAttached Filesswapping into another shell!
you have the two side by side so this makes the swap even easier . besides all the mechanical parts you also want the engine harness and ecu . then literally as you unbolt a part from one car . carry it over to the other and swap it . swapping to the GT harness eliminates any jumpering or wiring issues mentioned above
