Hi all, i am a new member looking to learn more about my 97 protege dx.
New member
Welcome to CP.
welcome!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Welcome.1990 Protege 4WD
1 3 5
2 4 R
