I just picked up a 1989 Base Mazda 323 for cheap with ridiculous low mileage...had no idea about these cars, and through that, found out about the GTX! Might buy one someday, who knows?
Thanks! I didn't realize what a rare find it was...the previous owners took good care of it, alignment is good, tranny and engine still running strong, and it starts up nicely. Pretty much only have 3 minor things to fix, passenger corner light, passenger side mirror and trunk lock.
yeah, definitely! I was surprised to find it had only 62k miles on it, and Carfax confirmed it too! Previously owned by a 91 year old man who averaged about 1500 miles/year for the past 7 years.
