Evil is right. The two thick wires will be Black/yellow and ( if I remember correctly) Black/ red. If you temporarily bridge the other two your reverse lights should come on.
DeeAOne's BF KLDE Swap.
I bridged the two thick wires and woot! The starter clicked and fuel came from the line! Now I just have to figure out why the starter pops out but won't turn. Progress! thanks for the help.
And the passenger side axle will be in tomorrow as well.
'88 323 sedan, K-swapped..
Originally posted by DeeAOne View PostI bridged the two thick wires and woot! The starter clicked and fuel came from the line! Now I just have to figure out why the starter pops out but won't turn. Progress! thanks for the help.
And the passenger side axle will be in tomorrow as well.FE3 POWA1985 Mazda 323 BF5P - FE3 powered
I'll see if I can scan some engine management diagrams at work for you....if our scanner does A3 paper!! Pin nos. on the ECU are likely to be the same. Try http://images.geekazoids.net/ecu_pinouts1.jpg and same with pinouts2.jpg Wire colours might not ness. be the same and be careful whether it is the wire or pin side of the plug that your are looking at. Hope this helps.
Originally posted by Pommyvince View PostI'll see if I can scan some engine management diagrams at work for you....if our scanner does A3 paper!! Pin nos. on the ECU are likely to be the same. Try http://images.geekazoids.net/ecu_pinouts1.jpg and same with pinouts2.jpg Wire colours might not ness. be the same and be careful whether it is the wire or pin side of the plug that your are looking at. Hope this helps.FE3 POWA1985 Mazda 323 BF5P - FE3 powered
was hoping to get to the junkyard this weekend for a halfshaft but of course 100% chance of rain until saturday. FML. cant attempt to start it either since i wont have an axle in it. so i wait...
I'm hoping to remove the motor/trans from the mx3 this weekend so I can get that braket for you and if you can verify the half shaft is for sure 100% the same between the mx6 and mx3 I can sell you that as well1993 Protege LX-Midnight's shadow SOLD
