Originally posted by DeeAOne
View Post
DeeAOne's BF KLDE Swap.
Well its weird because usually no one even takes a second look when they don't even know what it is. Lately though I've had numerous cars try to get me to run just in the past few days.
'88 323 sedan, K-swapped..
maybe its from the magazine article lol-Jack
who knows. lol
so i got my AEM wideband hooked up and working. here are my AFR's with my AFPR set to 20psi.
cruising ~2.5k rpms in 5th - 13.9-14.3
idle - 14.5-14.6
half throttle to about 5.5k - 11.2-11.7 (not going to WOT since my motor is still in break in period.)
Its a bit on the rich side for sure, but i saw on somewhere that the ebay regulators sometimes work better without the vacuum line hooked up. I may try that and see where it goes.
You definately will get a bit more power with how much you shaved the heads. Think I will be going this route in all my future builds with my low compression pistons to bring it back up a bit.1993 Mercury Tracer, KLDE VItara build swap, Compound turbos, 12 injectors, 2 wastegates, 2 Megasquirts, 2 axles, 2 everything, why not
2nd Compounded KL in the world
idle - 14.5-14.6
Its a bit on the rich side for sure, but i saw on somewhere that the ebay regulators sometimes work better without the vacuum line hooked up. I may try that and see where it goes.Last edited by klzemx3; 03-08-2011, 07:05 AM.
^^mazda_powered said Dee's car was in an article, that's what I was referring too lol
1988 323 GT - B6T Powered
yea, we have another Mazda "celebrity" in our community again lol
Originally posted by mac1 View PostYou definately will get a bit more power with how much you shaved the heads. Think I will be going this route in all my future builds with my low compression pistons to bring it back up a bit.
Originally posted by klzemx3 View PostHappy to see that you got a wideband.Dont worry about the 11.2-11.7 a/f until you can go WOT.Stoker100 also sells eprom for the ecu,that you can try.Your regulator looks like a aeromotive knock off.If it is,you can get replacement diaphragm and spring from summit,if needed! :-)
Originally posted by Damkid View PostDam how'd I miss that thread!! Very nice Dee!!
idle - 14.5-14.6
