thats the reason i spend the money on new parts. it always finds a way to bite you in the ass in the end. good luck dude. hope the motor is ok and you caught it in time before any real damage was done
My KLZE Ford Festiva build thread
thats ****ty budhanded down to my old man : 1994 Escort gt
Race car: 1991 EGT BP/bpt
http://www.wihandyman.com/forum/show...racecar-s-life
daily: 2004 mazda 6
http://www.wihandyman.com/forum/show...678-TheSexySix
Welcome to Canada
''It's a shame that today's car forums have "fashionistas" instead of gear heads''
Well my buddy at work told me today that he's once had the same thing happen but with a new pump, he let it sit for months with no fluid and the seal dried up and starting leaking, chances are this is what's happened with mine
Either way tomorrow I should have a new pump in my hands and hopefully tomorrow night it'll be back up and running... Again lol
1988 323 Station Wagon - KLG4 swapped
1988 323 GT - B6T Powered
2008 Ford Escape - Rollover Survivor
1990 Festiva - First Ever Completed KLZE swap (SOLD)
If no one from the future stops you from doing it, how bad of a decision can it really be?
the most annoying part of this though, is he has to pull the engine/trans out again lol-Jack
Nope I should be able to do it in the car lol went I changed the timing belt and had to put in a heli coil I did it all in the car, the reason I pulled the engine last time was to change the clutch lol
But I got my new pump today
oh sweet! I thought you were SOL for room lol, lucky man-Jack
Lol I'm actually just finally going to change the pump today actually
good luck dude-Jack
2 1/2 hours to change the pump from start to finish
Here's how far down i had to tear it apart
Ya I was actually surprised how well it went, other then a bit of fighting to get the timing covers off it went really smooth
good stuff, up and running again. go visit a priest to exercise the demons from it so you get no more issues lol91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Lol well yesterday I put probably 7-800 kms on it and the trip was trouble free so hopefully it stays that way for a while lol
