Originally posted by azgtx
View Post
1988 GTX Restoration - Going To Be Fun!
I was looking at the chariot gauge system that uses an app to talk to the gauge controller so I could use an old Android phone or tablet as a gauge pod. I might just ditch that and go with the MS and the virtual dash. Then again, I never have time to do anything...
Sent from my Nexus 5X using Tapatalk
Sweet!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
After 6+ months on non-starting issues, I have the car running again...finally! The culprit was the ECU to engine main harness that was previously tampered with, I removed it and replaced it with one from my donor GTX. So pleased that the car is running again after a frustrating many months
I also lifted my car as high as it could go to save it during the devastating Hurricane Harvey (Aug. 26th to 28th) - luckily I was dry during the storm and while it was up in the air, I replaced the coil over springs with Ground Control springs, which are 4.5 lbs lighter overall and I was able to get the car a bit lower as well.
So here are the pictures from last night.
Yasin
man thats so clean.
What springs did you have prior 4.5lbs a piece is a pretty significant change. did you change the spring rates at all?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by BFMRGTX View PostWas it the ECU or the wiring harness that was changed?
ahh that makes sense, what spring rate(s) are you running now?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
do you have any drive time on the new springs yet? curious what your thoughts are for this setup...
Im running 275 Front -- 250 Rear for me it feels like i could still go softer in the front, 225 maybe.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
