I am looking for the rear flange on the propshaft. Does anyone know the item number or know if it would be the same as a Miata or rx-7?
Propshaft rear flange
I would not be surprised to see it interchanges with same era Miata but this one I am not sure of.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
I also do not know for sure but most likely it will be the same as a 1.6 (90-93) miata. These use the same size ring gear as the GTX.
The RX7's and later1.8 miatas used a larger diff, and swapping a 1.6 miata to the 1.8 diff requires swapping driveshafts.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
