i took my whole intake apart and found oil all trough the turbo both sides. fun looks like im into a full rebuild as there is water in the oil. oh boy the joy of owning a 20 + year old car.
Sounds like the intake return line is pouring oil from your VC to the turbo and through the instake pipes. Try replacing your PCV (On the otherside of intake/at the manifold), and adding a catchcan between the hose from the VC to the Intake routing above the J-Pipe. May fix your problem. While doing that, check your turbo for shaft play. If it moves any, you may also have a blown seal among other things. Then do a leak down test for compression and determine if you have a blown headgasket.
Simple as that.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
oh ive done that it worked for a bit but i still had a vast amount of blow buy. the turbo is shot oil on both sides with shaft play now its time for me to decide what to do i have another gtx with clean motor w/ vj14 that i can swap out or rebuild this motor strong and find another vj11. decisions decisions88 323 bf (parts)
88 gtx (project)
88 gtx (project)
91 323 lx (sadly sleeping in the snow)
94 toyota pickup (not happy)
05 mazda 3 (DD)
91 mustang w/ 351w (sold)
too many projects
I bought nylon washers to use as bushings to finish getting ready to hook up my new rad. I Hammered the dent (most of it) out of my custom intake pipe so that I can re-use it for the time-being until I create some suitable replacement. Just about ready to get the rest of the car back together.
Bout danm time larry.
Got new MazdaSpeed Motor Mounts, and had them installed. Jason found a Broken Front Mount, so that would explain why my engine felt so danm sloppy! So Much stronger now, but it vibrates EVERYTHING!!! But with stiffer mounts, its to be expected. Atleast it can handle a little more power now.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
Oh!!!! BurrrrrrrnnnN!!!!!
1988 White GTX - #1 parts
1988 White GTX - #5 Rally car
Originally posted by 808 View PostOh!!!! BurrrrrrrnnnN!!!!!
Okay, maybe it's my age, but I am not exactly sure what "F and F" stands for..... Help me out guys (without too much ridicule... C'mon, I have the courage to ask you for help on this on-line or the stupidity....)
My dad and I put in the reman'ed brake master cylinder...bled the brakes...had lots of air in em. Also swapped the tires front to back. The thing really stops now. lol
If need be, hit up the local napa, atuozone, schucks, etc for the hose. The dealer is likely not going to carry one. They can be ordered however. I can send you my spare if need be. Its used but if I recal, in good shape. If not, have mazda overnight it to the dealer. Its pretty simple. You better as hell be drivin that thing down here!
Have you fired it at all yet?Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
