Yesterday I found out that my walbro pump was'nt working properly. It is pouring out fuel like when you slightly crack the pipe with the graden hose attach. Apparantley the filter got corroded and some of the particle went in the pump and start clogging it. I am now i need of a new fuel pump
got the hatch running tonight12 cbr250r: daily ride
01 saab 9-3: daily
98 gsxr 1100: for sale
93L: money pit/ space waster
92GL: low and slow beater
90?: the rust free shell
89L: for sale
89L: parts
76+80 vw dashers: for sale
That was going to be my guess, no fair! :p
Bulbs are likely to be the problem in that case. Easy to change. If not, I would check your boost sensor, make sure its plugged in, and connected correctly.
I finally got my engine problems squared away, and now about to cross over to her first 100 mile mark. 400 more till her second oil change! Its so nice to have my car back!Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
The high beams i would say is most likely the combo switch.
1988 White GTX - #1 parts
1988 White GTX - #5 Rally car
Originally posted by DeeAOne View Posti wish i had a boost light.
i have that cluster swapped in my car because the base cluster sucks, but no light.
Originally posted by LN323 View PostLike Familia said.... it might not be that difficult to just change out bulbs or if it is the combo.... I hope the dealer stocks that item and that it's cheap.
'88 323 sedan, K-swapped..
i think something inside the light control is broken i took it apart last night and i think there is something that's suppoed to slide but it's not sliding so that's why the highs wont work. who knows, i looked on ebay for a new cluster but none of them had the same setup so i'll just live with sometimes working high beams. i might just leave th turbo light as is until something bigger happens needing the cluster taken out.
