Originally posted by Bob Martin
View Post
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
absolutely nothing.
Originally posted by trailrider098 View Posta good chance to replace the keyway on the crank. My b6t was starting to wobble when i got rid of it. its not that hard of a job at least
'88 323 sedan, K-swapped..
Very common.
1988 White GTX - #1 parts
1988 White GTX - #5 Rally car
Originally posted by BFMRGTX View PostI feel your pain, Bob. Both seals are weeping on my block. Still don't know how or why it's happening; I've followed the FSM to the letter.
Terry
DeeAone- there was a recall to fix the keyway at one point IIRC"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
The crank pulley wobble is not only caused by a possible worn keyway/cranknose issue.
the other reason is the drive pulley on the crank that drives the alt/PS/AC pump belts has a vulcanized rubber sandwich piece between 2 metal pulley pieces. This rubber fails over time and allows the pulley to wobble.
Its not always the crank keyway.
Even my BPT pulley wobbles a bit, and I know its not the cranknose or keyway.
Originally posted by trailrider098 View PostThe same thing happened when I built my bp, the second time that I had to do it I dipped the seal in oil before pressing it in. I don't know if it helped but it dosent leak anymore.
PS: Yes there was a TSB for the crank issue. I know of one GTX in 1995 that got a new crankshaft installed under the TSB after the nose snapped off. That was keith Armbrusters GTX at the time.
I remember reading a post on the yahoo forum regarding the crank keyway issue. The person (was it John Jackson?) stated that the keyway failure was most likely due to the design and placement of the pulleys, and the stress it caused to the crank pulley. He said that it was best to keep the belts (AC, PS, Alt) as loose as possible, w/o them squealing, to keep the load minimized.
Or something to that effect.
Originally posted by BFMRGTX View PostI remember reading a post on the yahoo forum regarding the crank keyway issue. The person (was it John Jackson?) stated that the keyway failure was most likely due to the design and placement of the pulleys, and the stress it caused to the crank pulley. He said that it was best to keep the belts (AC, PS, Alt) as loose as possible, w/o them squealing, to keep the load minimized.
I don't have AC but after reading that I went out and loosened all my drive belts!
Originally posted by DeeAOne View Postwow thats crazy. this was just a few weeks ago. bolt was no where to be found. i was on the interstate.
Must have made a good mess in the timing belt area.
Good thing the engine is a non interference unit, or else all sorts of engine damage could happen.
