I finished painting the dash pieces and was going to put the dash back together but,...just got lazy. I did get some front seats from a '93 Pro.
What did you do to your BF today???
Finally got some goodies ordered for my White GT. Now I can start rebuilding her from the brakes/wheels up. Getting:
1. Steering Rack-Reman
2. Front and Rear Drilled/Slotted rotors
3. KVR Brake Pads
4. Corksport SS Brake Lines
5. Brand New half Shafts
6. Eurethane Control Arm Bushings
7. Swaybar Bushings
8. Possibley Intrax Lowering Springs on Tokico's if LN323GT likes his new Coilovers for his GT.
9. Powerdercoating the Stock Rims
10. New Tires
Still lots more to do after this, but this gets me started, and once this is done, That leaves the fuel system, Turbocharger rebuild, Transmission Overhual and Engine Overhual. If I play my cards right this year, I could have this thing on the road by late summer!!
Im getting pumped to get this car done.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
2013 Velocity Red Mica Mazdaspeed3
Hey Clay, I appreciate the offer, but Im going for a new molded carpet once I get to that point. Plus, I figure the gross and dirty carpet will work fine for when im tracking greese and dirt into the car when im rebuilding it. Found a site to get new molded carpet in any color for the car, so im going that route.
Thanks anyways.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
I have over 700 miles on the new rebuild and now the tranny is starting to act up. When im sitting at a light and I go to put it in first... It locks me out of first and second. I have to put it in third and move up and then put it in first. Im gonna change from gl5 oil to dextron atf and hopefully it will help a lil. otherwise I have to get it rebuilt and spend a whole lot more money that I dont want to spend
I'd only run atf if you're in -0 degree weather and seeing how you're in Florida I'm guessing that's not the case. Sounds like you have other problems...
1988 White GTX - #1 parts
1988 Black GTX - #2 reliably broken touge monstar (294,000 miles no rebuilds) - dead
1988 Blue GTX - #3 in progress (view here)
1988 Blue GTX - #4 BPT swapped weekend warrior.
1988 White GTX - #5 Rally car
Originally posted by noshatch View PostThats what I figured. I am about to give up. I need a car that will be abke to drive everywhere without having ti fix it everydayMazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
Originally posted by FamiliaGT View PostThis is exactly why when I take on a project car, I have the whole running gear checked out or rebuilt before depending on it. Im having my GT's Engine, Transmission and Turbo all rebuilt just to make sure it runs like new when I get it back together. Its a slow process, but it will get done. Which car are you driving again? GTX/GT?
