the dash cluster wont light up at night so i cant see how fast im going. all other lights work(headlights, stereo, overhead). the fuse isnt popped. before i start ripping the dash apart is there something else i should check?
no lights behind dash cluster
i just remembered, the previous owner replaced the ignition tumbler before he sold it to me and instead of just replacing the tumbler he swapped in a whole new steering column for some reason. i think he messed with the wires going to the dimmer switch because the fog light toggle to the left of the dash dimmer doesnt work either and the whole unit is loose and coming out of the dash. im not familiar with the wiring under the dash on these cars, should i start by checking the connections at the dimmer?
