I have a 1991 ford escort gt with the original bp motor. It is turboed with the whole nine yards. Anyways i had my whole set up on a 93gt and drove it til i blew up the bottom end. It still ran just had a knock on it. i took everything off the 93: head with intake manifold and injectors still attached, turbo, manifold, wiring harness, ecu and put it on my 91gt. I am having issues starting the car now. I have checked spark and fuel and know i have that. Also i have set the timing belt to spec as per escort manual. (Placed car at tdc and lined up the cam gears properly). It does turn over with no issue.
The car has good compression, pulled fuel rail and watched injectors and pulled the spark plugs and tested spark.
I checked the ecu and it is throwing 2 codes. 25 which says it is fuel pressure regulator solenoid and code 41.
Does anyone have input on what could be the issue? Any help would be greatly appreciated.
![Smilie](https://www.clubprotege.com/forum/core/images/smilies/smile.gif)
