Got new starter in my 91 egt finally after a long time of slacking and the starter turns over with direct power and starts the car no problem. It just wont turn over or do anything when I try and use the key. Could it be the relay? i can hear something clicking but i cant find it, or maybe my neutral safety switch? any ideas?
new starter, wont turn over with key
check your grounds...I bet that's the issue.-Jack
^+1
I had the same problem. Replaced my starter and had this starting problem. Turned out to be a couple of things; poor connection with battery terminals and that negative ground on that bracket on the transmission had come loose somehow. Cleaned everything up and the problem went away.Project "Underdog" on Cardomain
239bmxican on
BP wagon build thread
i will check but this was random... i went out to the mall about a 25 min drive, came home, went down the road to the store less than a mile, I tried to leave a few hours later for work and had nothing... i had to pop start it. But friday it will be going on the lift to to check it out
91 Red EGT :: Daily: CRASHED/SOLD
