I got the car in February 07 for $2700 with 110,512 miles.
The first mods I did was kemanize the intake and pull the knock sensor.
The car came with its 6-disk CD changer and speakers ripped out (literally), so I purchased a Pioneer headunit and speakers.
I wasn’t planning on buying rims anytime soon, but then I saw the Enkei OR52’s and feel in love with them. I got them in 17x7 with Falken Ziex ZE-912 205/40R17 tires.
Then came a DynoTune Nitrous wet kit and 3” ZXtuner intake with a Vibrant Performance filter.
Somewhere along here I got a B&M trans cooler and did the shift kit mod. I also got a Grille-Tech grille.
I got pretty good at e-brake 180’s and “drifting”. One night while showing off for some friends, this happened.
I ran off into a ditch and hit a stomp. It pushed the front frame over about a quarter inch. Lesson learned.
I removed the dash and clean all of the air ducts and deleted the A/C, I also removed the rubber firewall sound deadening (which turned out to be only 10lbs max of weight reduction, lol).
The auto slush-box wasn't cutting it, MTX swap time.
Scored a '98 ZX2 trans (only ZX2 year with Escort GT gearing, in 99.5 they went with longer 3-5th gears). Also got a ZX2 S/R spec Borla muffler.
Spec stage 3 clutch.
After it was all done, the car felt amazing! Would pull quite hard and was very responsive. Drove it only for two mouths then changed the oil, only to find a sh!tload of coolant in it........
The verdict was a warped head. As CARFAX stated the car started its life as a rental, there is no telling how much it had been abused/overheated, eta.
So the tear down began.
