have you ever used the e85 lucas fuel treatment? i add it to the tank once a month, otherwise id just run some 93 in it once a month...
2011 mx-3_4evr's turbo MX-3!
Originally posted by jinx View PostI found similar **** in my tank filter and pump screens when the walbro died. It's gotta be a byproduct from the 10% in our local fuels.. The stuff is black/grayish almost glue like tackiness to it.
Originally posted by yunvmyegt View Posthave you ever used the e85 lucas fuel treatment? i add it to the tank once a month, otherwise id just run some 93 in it once a month...
glad to hear you got lines antonio!!! you need to keep the mx3 on the road---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by yunvmyegt View Postits more to keep the ethanol from sucking up moisture when it sits or get humid....but also keeps the system clean
Originally posted by FE3-323 View Postglad to hear you got lines antonio!!! you need to keep the mx3 on the road
front tires????? WHY???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I discovered that not running a factory oil cooler is bad on a turbo set up lol! I took mine out when I was running N/A and it was fine back then, but now that I'm turbo, my oil gets really hot/black and drops pressure (non synthetic). I'm picking up a RX-7 oil cooler and mating that with a oil filter relocation kit. I hope people can learn not to remove your OEM oil cooler when you are boosting from my experience
what was your oil pressure dropping to?? I've seen mine go to about 18 when it over heated on me the one day, usually it's dead on 20psi @ idle once it's warm though, 40 while driving.-Jack
this forum misses you sir---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
