Here is the list of whats coming up for this summer. Most of it has been installed/done, the big change was in the block and head for this year
Block
Rock auto cast 9:5 CR .040 (1.9L)
B6T rods
Balanced and polished crank .010 main & rods
ARP main studs
ACL RACE bearings
OEM water pump
Shimmed oil pump w/ BE billet oil pump gears
Milled block
VHT flat black painted block
Head
Port & polish intake and exhaust
Shaved
GTR cams
OBX cam gears
ARP head studs
Mazdaspeed billet oil cap
Toyota Supra PCV
Intake
GTR intake manifold
4 wire TPS
GTX intake pipe
3" filter
Exhaust
GTX exhaust manifold (port & polished)
Corksport downpipe
Turbo
VJ20
FMI w/ 2.5" pipes
Top Fuel 1000 BOV
Fuel
E85!
460cc injectors
Walbro 255 fuel pump
Engine management & electrical
Megansquirt I V3.0
Glen's garage wire harness
Wasted spark (DSM coils/90-93 miata CAS)
Launch control
Separate engine harness from chassis harness
wire tucked
Battery in the trunk
Fuse box under the radio
Drivetrain
G-series
F1 Clutch- heavy duty pressure plate & 6 puck disc (KL series clutch kit)
F1 flywheel
Corksport SS clutch line
Homemade short shifter
M-Factory LSD
Taller 5th gear swap
Oil cooler ready
Suspension
Polyurethane bushings (90A front, 70A rear)
Probe/MX-6/626 GC coilovers
KYB GR2 struts
Corksport front strut bar
Elm joint sway links, all 4
Brakes
rear disc conversion
SS brake lines
Interior
All black interior w/suede and leather!
Mazdaspeed pedals
95+ protege metal shift knob
Megasquirt din plate
Innovate wideband
Innovate oil pressure gauge
Innovate boost gauge
Stereo
Pioneer deck
Infinity front speakers
Alpine 800w amp
2 cheap a$$ 10" subs
1.2F capacitor
Exterior
F/R GS spoilers
Projector retrofit headlights
HID kit
Front clear blinkers and markers
Wheels/Tires
17x7 45+ Drag DR-17s black with polished lip
205/40/17 Goodyear F1
The block is ready to be assembled, but I'm going to wait till spring. The head needs work. I'm going to port and polish it, have new valve seals installed, and get a valve job done to it. Stay tuned for pics and more updates!
-Antonio D.
Block
B6T rods
ARP main studs
ACL RACE bearings
OEM water pump
Milled block
Head
Shaved
GTR cams
OBX cam gears
ARP head studs
Toyota Supra PCV
Intake
GTR intake manifold
4 wire TPS
GTX intake pipe
3" filter
Exhaust
Corksport downpipe
Turbo
VJ20
FMI w/ 2.5" pipes
Top Fuel 1000 BOV
Fuel
E85!
460cc injectors
Megansquirt I V3.0
Launch control
wire tucked
Drivetrain
G-series
F1 flywheel
M-Factory LSD
Oil cooler ready
Suspension
KYB GR2 struts
Brakes
SS brake lines
Interior
Mazdaspeed pedals
Innovate wideband
Stereo
Pioneer deck
Alpine 800w amp
1.2F capacitor
Exterior
F/R GS spoilers
HID kit
Wheels/Tires
-Antonio D.
