OK guys have been searching like crazy on there and mx3.com and i cant find out much can i use the v6 cluster out of a 92-93 mx3 on my 94 swap bp mx3 All all can find in my area is v6 ones. And can i use my gear that goes in the tranny off the protege or egt that makes the speedo move.
mx3 cluster
ya might want to snap some pics of that Antonio lol or do a paint picture, sounds neat.-Jack
The cluster that I am using in my '95 is a v6 cluster from a '92 and I used the speedo cable from the Escort GT. Everything works fine. It is really tight at the back of the cluster with the cable driven speedo, but you have to cut out a couple plastic and metal brackets to make it fit. Like I said though, I never had a problem with it.
Jeff
all V6 clusters are electric drive. only 92-93 RS have the cable drive speedometer. Either way, the V6 tachometer won't properly read I4 engine correctly because of the difference in the voltages in the tach. (think of when you buy an aftermarket tachometer, you get different 'pills' for 4 cyl, 6 cyl, 8 cyl, etc)
I have a similar problem i have a 92-93 speedometer and a mx3 sohc 93 speed sensor so yes it is mechanical to fit the mechanical cluster but the driven gear wont go perfectly in the bp transmission i also have the stock 1994 electronic cluster from my mx3 but dont have the electronic bp sensor do you have and suggestion?
