I have a set of brand new OEM lateral links that I need to remove the rubber bushings from. Just looking for some suggestions for how to do it the easiest, since it seems like people have trouble removing even 15+ year old bushings. I think that using my 12 ton shop press will be the most effective, but I'm open to any suggestions since I've never had to remove a bushing before and since these bushings are still completely solid I think it's going to be a little harder than just popping out a worn one.
What's the best way to remove OEM bushings from a brand new part?
torch. Heat them to hell.
thats what I did when I put the supro kit on my EG.Beater=/= Sleeper
warm up the lateral link around the bushing, and then press it out. they slide right out that way. then you just have to clean up the bore.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Home remedy vs machine shop
mmmmmmmmBeater=/= Sleeper
home remedy looks to be much better hahaha. also a little more fun1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
