Was busy scrapping ice off the car. Ice was like an inch thick all over.
what did you do to your non-Protege today?
It's got more than enough mods to keep me happy. Right now it's in winter mode91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by shorestiva View PostB235 for my Saab, zm-de for my festiva, b6-me just because $50
benefit of the ZM-DE???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Head is supposed to flow better than b6t and has solid lifters.
Build Threads - Hybrid B6/ZM-DE engine build - My 1.6 turbo build. The parts list as follows: • Wiseco +1mm pistons and custom rings • Carrillo A-beam rods • ACL race bearings • Supertech +1mm intake/exhaust valves • Factory AT cams • Ported head • Polished and balanced crank • Cometic head gasket • ARP studs top and...12 cbr250r: daily ride
01 saab 9-3: daily
98 gsxr 1100: for sale
93L: money pit/ space waster
92GL: low and slow beater
90?: the rust free shell
89L: for sale
89L: parts
76+80 vw dashers: for sale
interesting adventure. I did see some note into the ZJ engine & VVT. perhaps investigate into that head further.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Zj was in Mazda 2 and from what few pics I've seen I think it's based on the mzr not the b series. The zl-ve is vvt they pop up at importers every once and awhile.12 cbr250r: daily ride
01 saab 9-3: daily
89L: for sale
89L: parts
Made up a new set of mounts for a b6d with festy auto.
(ignore the b3 in the pics lol it was the only easy way to mock it up)
For the front trans mount I just trimmed down one of the bushings so I only had the make the lower part of the mount.
Rear trans mount
01 saab 9-3: daily
89L: for sale
89L: parts
custom work for sure. you have some really clean bends---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I cheated and cut up some square tubing for all of those. :D I did bend up part of the rear mount with a friends brake but I forgot to take a pic of it.12 cbr250r: daily ride
01 saab 9-3: daily
89L: for sale
89L: parts
^:p---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
A Miata with high-performance summer tires is not the ideal car in the snow...
Can't get up my driveway.
