Originally posted by ftjandra
View Post
what did you do to your non-Protege today?
Originally posted by atomicEGT View Postthat sounds like so much fun. details? that's not F2T-swapped, is it?
This one well.... I'll just copy/paste.
Modifications:
AMS built motor with ~20k miles on it
JE 9.0:1 pistons
Eagle rods
ARP hardware throughout
Ported and polished 99 BP4W head
Flyin' Miata Stage 1 clutch
Fidanza flywheel
Toyota COPs (Replaced with OEM Denso units less than 1000 miles ago)
Begi GT2554 kit (Manifold thermal coated)
Begi turbo heat shield
Begi Intercooler/piping kit
Begi "race" coolant re-route
FM 2.5" downpipe - Thermal coated
Enthuza 3" exhaust
RX8 yellow top injectors
M-Tuned fuel rail
Walbro 255hp pump
Megasquirt 2 Enhanced PNP (Brain Built). Sequential fuel, "gslender A/C idle up" circuitry/code.
Koyo 37mm radiator
AEM wideband
AEM water temp
AEM boost gauge (sending unit may be toast, currently running a cheap autometer) All AEM gauges are the silly expensive ones with stepper motor ****s.
15x8 6ULs
Mazda Competition motor mounts
Slotted rotors
Hawk pads
SS braided brake lines
SS braided clutch line
Interior
Pioneer headunit of some kind (aux input)
Aftermarket speakers of some kind (headrest speakers work)
IL Motorsport center console (baller!)
Momo Competition wheel and hub, wired properly so horn works
IL Motorsport chrome door handle cups
I'm not actually sure which turbo is on it. Supposed to be a 2554, but i've never felt a 2554 hit like this and pull like ****ing crazy like this on the top end. It's easily as gnarly as FM's shop car "Igor" is, and this is only running 12-13psi right now.
I don't even have VICS hooked up yet. Gonna be straight up stupid. If it IS a 2554, i want to see what it does if i spike it to 20psi in midrange.
Originally posted by atomicEGT View PostYou want some Frog Arms for that thing? I have a bunch of leftover nerd **** for the Miata lying around that I don't feel like putting on my dad's 97M
Yes. You still have my number? Text me, baby.
By the way, i'm told the MSM is a monster at 16psi and 5-8 degrees more timing across the board. Dude is reconsidering building it because it kicks like a damn mule and is breaking traction at the top of 3rd gear.
Dat bay. Cute little baby turbo.
the 90 degree angles look like dick, it almost seems like something you'd see on some Honda forum except it's not made out of PVC piping.
also, yeah, the valve being so far away from the cold pipe seems super dumb, though it's probably like that because of the way the valve is shaped. only recirc valve I can think of that vents in the same direction (? plane? four hours of sleep means I don't know what word I want here) as the flange is one of those weirdo TiALs.sigpic
92 240SX: KA/T25, nerd mobile
