Originally posted by atomicEGT
View Post
what did you do to your non-Protege today?
It seems like it would be simple enough to make a bracket to hold the disty, then it would be a matter of running a belt-drive setup to go from the cam gear to the end of the disty like the 20V 86 nerds do... how hard could it be?
I do wish there were some way to just use a CAS and coil packs with the GTR computer thoughsigpic
92 240SX: KA/T25, nerd mobile
Cut a hole in the firewall......done?92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
I'd prefer not to- makes basic maintenance harder, plus then I have to worry about it interfering with the wiper linkage. I mean, as a last resort, sure, but I've seen them run off of the front of the cam before so it's definitely possible.sigpic
Drove the Volvo in light snow this morning. It remained well composed. Only broke traction once, and then only briefly, during a harder-than-necessary straight line acceleration in second gear.1990 Protege 4WD
1 3 5
2 4 R
sweet!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by atomicEGT View PostI think the vented quarter window was the best thing I did to my Miata, I ****ing loved that ****
if only kg works actually released this
I just installed a tachometer from a spare cluster in the Volvo. No more giant analogue clock. I'll miss it a little, but I really want the tachometer, so it's staying. I fiddled with illumination bulbs while I had it apart and got them both working. And I removed the bulb from the annoying shift indicator light. I don't need a light to tell me when to shift.
I'll take a picture tomorrow if I don't forget.
EDIT: I didn't forget. Here is the crappy picture I took with my phone.Last edited by me109; 02-02-2015, 04:16 PM.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by bogaut View Post
That's AWESOME. o_O
Thinking about getting the Project-G rear "glass" with 3 more pop vents. Bet i could sell my stock glass for almost enough to cover it.
