Changed out spark plugs and coils in the 1 series. It was actually pretty easy to do. If it wasn't 10 degrees out when I did it, might have been fun.
what did you do to your non-Protege today?
more into on the bilstein setup??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postmore into on the bilstein setup??
I'm revamping it a bit, so i'll just list what i'm going to end up with.
MSM Bilsteins (circlip moved down an inch)
AllStar sleeves/perches
Hyperco 6" 600/400lb springs f/r
Eibach isolators
Hyperco zero rate tenders
Custom extended top hats
Previously had ready to go the same sort of deal, just with ebay sleeves/perches and 7" QA1 550/400lb springs. Drove a well set-up 99 Sport with a built motor and EFR 6258 with a nice Bilstein setup on Satuday, convinced me to spend a little extra money into something that should keep me satisfied for a year or two. I can revalve my spare set of Billies later to handle 700/400.
i have yet to experience the wonders of a well setup miata---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I've experienced a few in wildly different guises.
1) Keith Tanner's Targa Miata (later V8 form)
2) FM's "Igor" shop car
3) FM's "Nancy" V8 NC
4) Marcus Luttrell's STR 99 Sport, probably the fastest STR Miata in the country
5) My own MSM
6) This EFR car i drove this past weekend
I'm kindof.... with this build, taking a combination of #1, #3, and #5.
fancy freaking piece!!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Awesome!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
