Originally posted by atomicEGT
View Post
what did you do to your non-Protege today?
Originally posted by atomicEGT View Postare we betting on this? my vote is 137 ground squirrels.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
I installed a new throttle body in the vw bunny. Now it can accelerate past 30km/h. Also installed some h&r sport springs in my new to me 06 Jetta. Gives it some much needed attitude.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
That'd be a pretty crappy betting game. Results are in the video description.
RPM output was slightly wrong on the dyno, accounting for that ended up around 133whp on a very conservative Mustang dyno. On a Disneyjet she should be north of 140whp. Daaaayyyyuuuuummm so much powerz!
Gonna try to break 150whp on an internally stock motor over winter. BP5A intake cam, Haltech Elite 1500, and a Honduh intake manifold are happening.
That is exactly how my BP sounded with my fancy header and 3" exhaust.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by 300zxrb26dett View PostThat is exactly how my BP sounded with my fancy header and 3" exhaust.
Pretty much, although anything above cruise throttle application was loud, but it wasn't bad in the car and didn't drone. You could hear the VICS switchover point though.
You have a wideband on that thing I assume?92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostPretty much, although anything above cruise throttle application was loud, but it wasn't bad in the car and didn't drone. You could hear the VICS switchover point though.
This thing is loud ALL the time. It's over 100db in the cabin at highway cruising speeds.
I didn't know if i was going with a newer Megasquirt or a Haltech after i sold my Megasquirt/MTX-L combo for it, so i didn't want to spend the money twice.
If i go Haltech (where i'm leaning right now), i'll use the Racepak out of the Escort and run no other gauges. (And then cut the hell out of my dash because race carrrrrr)
If Megasquirt, i'll need MTX-L, and Accutech SMi oil pressure, oil temp, and water temp.
Daily driver, stock gauges are fine. Car I am spending money on though I want to see whats going on.92 Mazda MX3 GS> For sale, $1750 OBO
In following measurements provided by a super great 240sx forum I bought some very expensive seat-belt bolts that are about 7cm too short. Still rocking the no seatbelt life for that.
Successfully managed to get the brake lights working proper and greased the steering column. Once I get the speed sensor swapped out and the backup lights hooked up it will be stupid close to road legal.Beater=/= Sleeper
