If you're interested in the first one, see this thread:
And here goes round 2!
1. When installing fasteners of any kind, it is always important that they are tightened the correct amount. An extremely stressed fastener in combustion engines are connecting rod bolts. The MOST correct way to tighten a rod bolt is:
A - with a torque wrench
B - with a bolt stretch gauge
C - applying a small amount of ATF on the threads of the bolt to help lubricate the threads, allowing a more accurate reading off of the torque wrench
D - torque with a torque wrench, loosening a 1/4 turn, and then re-torque
E - hand tighten, and then 3/4 turn with a ratchet/wrench
2. If the percent water content of brake fluid increases, its boiling point:
A - increases
B - decreases
C - remains unaffected due to brake fluid being silicon based
3. DOT 5 brake fluid is silicon based.
True or False
4. The stoichiometric air/fuel ratio for an unmodified 4 stroke combustion engine is:
A - 16.3:1
B - 13.6:1
C - none of the above
5. Which of the following 4 scenario's could potentially induce detonation?
A - a clogged air filter
B - retarded timing
C - a warped flywheel
D - an EGR valve that is stuck shut
6. What would be MOST indicative of a lean running engine?
A - high exhaust gas temperatures
B - 12:1 air fuel ratio reading
C - low compression
D - inaccurate TPS sensor
**BONUS**
7. Who has a faster car:
Me or you?
A - increases
B - decreases
True or False
A - 16.3:1
B - 13.6:1
B - retarded timing
C - low compression
**BONUS**
Me or you?
