Have we lost any engines with the cold weather?
    I know we all put antifreeze in our cars, right?
    1991 Protege LX with GTX swap, DD
    1990 4WD Protege with GTX swap, Project/garage decoration
    2006 Mazda 3 with 2.3, Her car
    1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
    with the BP you NEED anti-freeze anyway sinces its a cast iron block.
    but back to the subject at hand, we just had to do the headgasket on rusty323's B6T due to overboosting in cold weather.
      http://www.wihandyman.com/forum/showthread.php?t=47653
      my fs thread
        i run 15% antifreeze 85% water until it drops below 40 @ nighttime then the roles are almost switched
          all good here *knocks on wood*, i let my baby warm up to operating temps before i even pull into the street
          Originally posted by 90prtege
          have you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!
          Originally posted by Turpro
          Fk the family. Drugs and hookers take priority first
          bpt323: broom break
          CRZbrussian: that sux
          CRZbrussian: get swifer wet
          CRZbrussian: ****s aluminum
            lol, I don't think it's due to the weather though. I've had a suspected "lifter tick" for a few months.
            -Dennis
            95 Nissan Pathfinder 4x4 - 191k miles
            I'll be back in the BG game eventually!
              jason lost his to boosting on a cold motor right?
                I run all antifreeze, but warm up always before driving!
                  yep, even my 626 (n/a kl) i let warm up 5 minutes before workin the morning, and a minimum of 2-3mins any other time.
                  Engines only have to run 30 seconds to raise oil pressure and lubricate all the components tho...unless you're boosted haha, then i'd recommend a block heater!
                    i helped save a sohc BP so far. a friends car had a thick golden rust coolent. it was slightly leaking at his waterpump, and the color wasnt even slightly see through. it was by far the worst ive ever seen.
                    did two hardcore coolent flush's. still wasnt 100% clean. while doing that, realized the reason his cooling system was crap wasnt even just the fluid. his waterpump had destroyed itself. so ended up replacing that also.
                    ~PaTricK~
                    -Current car's-
                    What are you driving?
                      50/50 water and coolant, give it a couple of mins to warm up before i drive, no boost until its up to temp. Cars been ok apart from me leaving the handbrake on the other night and it freezing up, dragging the rear wheel up the road. Hammer and some de-icer soon sorted it.
                        i let my winter car warm up for 10min before i even think about leaving. its too cold to even try driving without the heat already going. lol
                        ~PaTricK~
                        -Current car's-
                          the BEST mixture would be 70% antifreeze 30% water. "straight" antifreeze will freeze at the same temp as like 38% antifreeze..
                          personally i run 50/50 in all my cars. not too often that we see -30* F temps...
                            yep, same here, 50/50 does fine..
                              If I can run 50/50 here and never had a problem, everyone should be fine with 50/50.
