This was not the best but showed me i need to do some major sus. work now if i want to go any faster. im only getting 1.9 60's and spinning the tires into 3rd with 24.5x8.5x13in slicks. I hooked up a 2step to dump fuel on the line to lanch the car in boost. I was making about 13psi off the line. So coil overs, struts and wheelie bars are next on the todo list.
this run i missed 3rd.
this run i did not get a good burn out because the guy pulled me to far out of the water box and it pulled the car bringing the rear tires into the water so when i tryed a 2nd burn out it did the same thing. ran a 2.0 60' on this run.
i was not happy with any of the runs but i was so screwed lanching the car i was loosing so much time. i was running low 11sec MPH so ill get it fixed and try again.
