yes of course!
My FE3 progress thread
looks good man! gotta make room you're running a front tie bar right? that should help keep things solid-Jack
if you box that area cut then there will be no issues with it being weak anyways. possibly end up being stronger depending on what you use.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
H- Transmission
Cleaned up the case nice & shiny like (wire wheel) - haven't wiped it off yet
cut the case to match the bearing race's (keyway'ed) so they don't spin in the case
Cleaned up some misc. slag & chamfered the edges of some important areas where it was lacking
about to start assembling it momentarily---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
so why did you cut into the car? clearance for the trans? trans case looks awesome!!!-Jack
^ thats the OE mount for mx6/probe GT's its only purpose is to keep the case held tighter in that area while the RTV dries it'll be taken off tomorrow.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
nice work dood. what's the goo behind your races? what kind of press do you have? Did you reshim anything?Rob's machina de destruccionOriginally posted by ragnarock01"America never would have gone to the moon without an LSD. It kept the rockets flying straight, and it'll keep me from going into a ditch."
i hate you and your shiny transmission pornOriginally posted by 90prtegehave you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!Originally posted by TurproFk the family. Drugs and hookers take priority first
bpt323: broom break
CRZbrussian: that sux
CRZbrussian: get swifer wet
CRZbrussian: ****s aluminum
ROb, thats just grease for ease of assembling the races into the case... ATF will clean it out in the first change anyhows
i have a 12 ton shop press (wish i would have bought the 20 ton for clearance issues)
stayed with the OE shims- as it turns out works mint like a charm.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
