New graphics
    Team Dynamics made in England light as S%#&. I'm rockin dees but in gunsmoke metal
    Tricks get applause... Style gets respect.
      Originally posted by jrally View Post
      You guys realize, the car flying through the air is an actual Escort Cosworth RS, not my car that's pictured first, right..?
      -Jon R.
      I noticed the damn front end and didn't think much of it lol. Oversite
        I forget the offset, but I'm pretty sure it was 45mm. They are pretty tough wheels for how light they are. I tipped the GTX up at a 45 degree angle, to it's side, at a track one day. No bending, no cracking, just a lot of scuffed up powder coat. Being silver over aluminum, you can hardly notice the scuffing anyways... (Not the best feeling, spinning out of control at 50-60mph without a cage or even safety harnesses!!)
        -Jon R.
          -Jon R.
          15x7 with a 45mm offset and they don't rub the struts? Are you running any spacers? With my 15x7 (41mm offset) Enkei's I had to use a 5mm spacer in the rear because the tires were rubing the strut body. I know you have the Hotbits coilovers and with the helper springs I imagine that there is even less clearance, no?
          --Ferdi
          If you can't differentiate between brake and break, you should go back to school
            No spacers, tiny bit of rubbing when hard corning, on the back struts. According to my records from GoodwinRacing, they were 35mm offset rims. I'll have a wheel or two off tonight, so I'll see if I can find any markings to confirm this.
            -Jon R.
